AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Symbol Builder Tamplate
1 REPLY 1
387 Views, 1 Reply
I was wondering if there is a way to set your default location for your "Attribute Template" in symbol builder. I'm having to locate it every time I go into it. In previous versions of AUTOCAD the default was the one i used and didn't need to locate it every time.
James
1 REPLY 1
PatMurnen_Adsk
Add the path to the project's Properties > Project Settings tab > Schematic Libraries paths. Move it to the top so it is the first path. AutoCAD Electrical will use the first path if it contains templates, if not then it moves on to the next path in the list until it finds one with templates.
This should not affect symbol insertion since whenever you insert a symbol, AcadE looks in each path until it finds the selected symbol.
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
”Boost
