Surfer requires multiple AESURFCONT commands on 2nd surf
I have and issue with the surfer in autocad electrical 2010 using windows 7 operating system.  The first time that you surf with the command it works as it is supposed to.  The next time you try, it requires multiple tries using the AESURFCONT command, usually anywhere from 10 to 15 times and then it will surf to the dest, or source you are trying to get to.  I have service pack 1 loaded for autocad electrical 2010. I also get "Nil" in the command line when it fails to surf.   Any help on this would be great.
Found the solution to this.  Unistalled service pack 1 for Autocad 2010 and problem was solved.
