styletable
styletable
rickstarosto4361
Message 1 of 1
styletable
rickstarosto4361
am having trouble with TableStyle drawing. My first attempt at using this was some time ago and trying to us it today I noticed I was updating this file which is located C:\Users\ras\AppData\Roaming\Autodesk\AutoCAD Electrical 2020\R23.1\enu\Support (OOPS), when I should have bwwn modifying the file here C:\Users\ras\AppData\Roaming\Autodesk\AutoCAD Electrical 2023\R24.2\enu\Support.
The issue is even when I update the correct TableStyle drawing the project is not seeing the updated file? Is there a pth I need to change? Or do I need to delete old versions of ACADE? I am using the ACADE 2023
Replies (0)
