Sheet Number Display
Is there a way to display the assigned sheet number, in a project, on an individual drawing?
TRLitsey
Hi there,
The variable is %S .  If you want to do this on a project I would suggest that you search this board or use ACE Help to look up the various methods for Title Block SETUP or Smart Title Block.  For this example everything in purple will automatically update with the ACE Title Block Update tool.
Good luck
Update tool
Please mark as a solution if this works for you, kudos are always welcome
