Sheet Number Appearing After Rung/Line Number on Ladders
davidmK4ZYJ
Observer Observer
davidmK4ZYJ
Observer
Observer
I'm having an issue when I insert a ladder, the sheet number always appears after the line number. I can't figure this out. I believe I have my setting correct, but I'm a newb to electrical.
arshdeepsingh404
Hi @davidmK4ZYJ
Any chance this is embedded into your title block?
What happens if you select all numbers and delete them, and then reinsert?
If none of these work, can you attach the dwg file here so we can look at what could be wrong?
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
JeffatPrimex
sounds like you have an WD_MRLH block defined in the drawing. Try removing any old ones and inserting a new ladder.
Best regards,
J.
