Selector Switch Standards
mabnerRDMKQ
mabnerRDMKQ
I am trying to find a standard for NFPA symbols, specifically a selector switch. When I draw in my selector switch symbols, the symbol represents the actual physical contact. In the example below the selector switch has one normally open contact. But in order for the switch to be set in the RAPID position, the normally open contact needs to be closed. That contact being closed is indicated by the state, "XO".
I am debating how the symbol should be drawn with co-workers. They believe that because the tail is pointing to "RAPID" and the state shows X for that position, the symbol needs to be drawn as normally closed instead of normally open. I want to make sure we are following industry standard.
Am I using the NFPA schematic selector switch correctly? On a side note, is there a standard anywhere for NFPA symbols?
alds02
I think the NFPA symbols are based on ANSI because there is a figure in my NFPA 79 book that shows "Selections from ANSI Y32.2/IEEE 315/315A Symbol Table."
In my opinion, you drew it correctly - don't draw anything as normally closed when the contact block is normally open.
