Secondary Catalog Error
selina_jeromeRKU85
selina_jeromeRKU85
I’m trying to create a new secondary catalog database for my company. When I first open AutoCAD and browse the catalog information, the primary catalog loads normally. However, opening the secondary catalog takes a long time, though it eventually loads.
After assigning catalog information to the first component, when I try to browse and assign a second component, I get an error saying the catalog format is incorrect (see attached screenshot). The only workaround I’ve found is restarting AutoCAD—then the secondary catalog works again, but only for the first component. When I try to access it a second time, the same error occurs.
Could someone please help me resolve this issue?
lauri_barnhart
@selina_jeromeRKU85- Welcome! Thanks for your question.
I wanted to follow up to see if you're still facing this problem?
If you've resolved this issue, please share it. It will help other community user find a solution to similar problems.
If the issue persists, let us know with an update so we can assist further.
Best,
Lauri | Community Manager
selina_jeromeRKU85
Hi Lauri,
Thank you for your message.
I still have this problem, its not been resolved yet.
Thanks.
rhesusminus
Did you try to fix the secondary catalog using the migration tool?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
selina_jeromeRKU85
Thanks this worked for me.
