Script Help
Script Help
sssf_23
Script Help
sssf_23
I created a script to delete a stamp by layer but not all of the script will do what I need it to do. I need help. I want to delete the stamp, zoom extents, purge all, save & close. The script works but for some reason the purge is not working properly. When I run it, it processes fine but when I re-open the drawing & try to re-insert the stamp, not all of the parts of the block come in. If I purge it manually it works but not with the script. This is what I have.
-laydel
n
stamp
y
z e
-purge
a
n
qsave
close
Can someone help me to see why it is not working properly.  Thanks
rhesusminus
Do purge multiple times in your script. 3-4 times.
The manual purge command can do recursive purging. That's probably why it works when you do it manually.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
sssf_23
I will try your suggestion & let you know how it goes. Thanks for the input. I appreciate it.
sssf_23
Thank you. This worked perfectly. I actually only needed (2) purge commands with a double space at the end to qsave & close. I appreciate all your help. You are awesome. I Actually have more scripts that I need to write, just staring out. I haven't gotten to them yet. Baby steps, one script at a time. Thanks 😊
sssf_23
I am experiencing another issue now. When I copy & paste the script on the command line it works. But if I drag & drop the script it gives an error "unknown command "z". Press F1 for help. I am using the Script Pro 2.0 app. I ran 386 drawings & they all said done but when I went to check the actual drawing to see if it worked, there was nothing. I removed close from my Script only qsave at the end. It's like it is not reading the script properly. 😕 🤔
