Confusing title, I know. But the situation is this:
I am creating a component (PLC, non-parametric), complete with TAG attribute and all other relevant info. The issue is, that when I go to insert in my panel layout, I can't see the 'TAGNAME'. I see the other information (INST/LOC, MAN/CAT/ASSY, DESC 1, 2, 3). It is the TAG that doesn's show up. When I force an insert (using the aforementioned component), it doesn't list a TAGNAME, and the component can still be selected (should I choose to do that).
Any thoughts on this? The component is created properly (OTHER components work properly)
Doug
Try changing the TAG attribute to TAG1.
That's a good point Jim. For some reason I thought he meant he couldn't even see the tag in the schematic list.
You are correct. When I select 'schematic list' as my insertion method, the TAG is not displayed in the selection pop-up, the other stuff is though.
