Report Connector detail to show attributes.
mark_hopleyEVTFY
mark_hopleyEVTFY
Can you show the connector attributes in the Connector Detail Report? Ex. Tag "TERM01J" = Value "A" , where the connector pin is A but you also have Tag "TERMDESC01J" = Value "GROUND MODULE ON FRAME 29" is the description of pin A but this can't be shown in the Report. What am I doing wrong?  As you can see there are no attribute selection to do in the report generator, Connector details data fields to report.
galashkina
Try using the "Component Wire List" report
