Read and Write Custom of a Block using autolisp
22352065NTPYQ
22352065NTPYQ
What is the autolisp syntax to read and write Custom of a block . It can be seen by selecting the object and executing command "PR (PROPERTIES)"  through UI.
I am using Autocad electrical 2025.
rhesusminus
You should ask about this in the Autolisp forums: Visual LISP, AutoLISP, General Customization Forum Autodesk
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
