project question
project question
project question
I started a project and I would like to change the titleblock template I have linked to it.  Any ideas?
Icemanau
Make the changes to your title block and save as a dwg.
If you are using the WD_TB attribute method, run the title block setup at this time and then save as a dwg again.
Use the Update/swap component tool to swap the old title block with the new one.
If you are using one of the WDT file methods, run the title block setup now and save.
Now just do a title block update and see if it worked...
If it all worked properly, open a blank dwg, insert the new title block and set any other dwg options to match your dwg standards. Now save this as a template to use for any new dwgs in the future.
Regards Brad
Brad Coleman, Electrical Draftsman
