Hi all,
I have a problem (one of many) with ACADE 2015 SP1.
It seems that it doesn't update the Scratch Database properly - if at all. Sometimes it doesn't even create a database and this causes reports to fail with "No Data to Display" in the commandline.
So I realise this is the root of all problems to do with loss of Cross Reference data, the AERESEQUENCE command doesn't work and crashes with the following error: -
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Windows.Data.CommandEditor.set_IsBusy(Boolean value)
at Autodesk.AutoCAD.Windows.Data.CommandEditor.SyncUpAllCommandLineState()
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 20.0.0.0
Win32 Version: 20.0.210.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcdbMgd.DLL
adui20
Assembly Version: 0.0.0.0
Win32 Version: 20.0.51.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/adui20.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 5.2.8.100
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdApplicationFrame.DLL
AdWindows
Assembly Version: 5.2.10.200
Win32 Version: 5.2.10.200
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AdWindows.DLL
PresentationFramework.Classic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.classic.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/accoremgd.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acmgd.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcCui.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcWindows.resources.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AceRibbonUtils
Assembly Version: 12.0.55.0
Win32 Version: 12.0.55.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceRibbonUtils.dll
AceRibbonUtils.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/en-US/AceRibbonUtils.resources.DLL
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AceLoader
Assembly Version: 12.2.0.8
Win32 Version: 12.2.0.8
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceLoader.dll
AceMgdUtils
Assembly Version: 1.0.5379.41927
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceMgdUtils.DLL
AceMonitor
Assembly Version: 12.0.1.1
Win32 Version: 12.0.1.1
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceMonitor.dll
AceMigrationUtil
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/AceMigrationUtil.dll
AceDBEditor
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/AceDBEditor.dll
AceCatalogBrowser
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/AceCatalogBrowser.dll
AceCatalogBrowserCommonCtrl
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/AceCatalogBrowserCommonCtrl.DLL
AceDataStore
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/AceDataStore.DLL
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
AceCatalogBrowser.resources
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/en-US/AceCatalogBrowser.resources.DLL
ElectricalMobileCompanion
Assembly Version: 12.0.53.0
Win32 Version: 12.0.53.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AceMobileCompanion.bundle/Contents/Windows/2014/ElectricalMobileCompanion.dll
FeaturedAppsPlugin
Win32 Version: 20.0.46.0.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2015/Win64/FeaturedAppsPlugin.dll
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcWindows.dll
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Microsoft.Expression.Interactions.DLL
AceMgdRibbonUtils
Assembly Version: 1.0.5164.769
CodeBase: file:///c:/program%20files/autodesk/autocad%202015/acade/AceMgdRibbonUtils.dll
AceCommonWrapper
Assembly Version: 1.0.5164.765
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceCommonWrapper.DLL
AceCatalogBrowserMgdRev
Assembly Version: 1.0.5164.929
CodeBase: file:///C:/program%20files/autodesk/autocad%202015/acade/ACECATALOGBROWSERMGDREV.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcLayer.resources.DLL
AcLivePreviewContext
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcInterfere.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/en-US/AcCalcUi.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
FeaturedAppsPlugin.resources
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2015/Win64/en-US/FeaturedAppsPlugin.resources.DLL
AceTaskDialogsRes
Assembly Version: 6.0.21.0
Win32 Version: 6.0.21
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceTaskDialogsRes.dll
AceTaskDialogsRes.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/en-US/AceTaskDialogsRes.resources.DLL
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AceCommandTooltipsRes
Assembly Version: 7.0.29.0
Win32 Version: 7.0.29.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/AceCommandToolTipsRes.dll
AceCommandTooltipsRes.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202015/Acade/en-US/AceCommandTooltipsRes.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
The error means that the components catalogue doesn't total up its "ITEM" numbers correctly and duplicates are rife.
Is there any way to force creation of a Scratch Database? I know it should do it automatically from project drawing data - but its just not happening and there is no evidence to suggest why?
Many thanks in advance for any helpful advice.
Cheers.
Chris.
