Announcements
Project and Sheet properties
FRFR1512
FRFR1512
Hi Friends,
When you create a sheet in electrical, you have the posibilty to overwrite the sheet properties with the Project properties.
Is their a way to overwrite the Project properties withe the sheet properties.
Many Thanks in advance
Accepted solutions (3)
ramesh.kambang
Yes, there are two ways:
  1. if you are adding new drawing (s) to project tree, click Yes when prompts "Apply Project Defaults to drawing setting"
  2. if the drawing (s) is / are already in the project trees, select drawing (s), right click > Properties then click Apply Project Defaults
You can also check the check the setting comparison, by right clicking a drawing > properties>Settings compare. Here you can select either match project or match drawing.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
jseefdrumr
I don't believe there's a way to do what you want ... you'll have to just manually reset all of your project properties so that they match the drawing properties you like.
Jim Seefeldt
Electrical Engineering Technician
ramesh.kambang
To overwrite Project properties with the sheet properties, in the Setting Compare click "Select All", then click "Match Drawing" and click OK.
Ramesh Kambang
jseefdrumr
Good to know! I've never had to do this, so I didn't even know that button was there.
Jim Seefeldt
