Hi @ABBASFADOO8109,
I am very sorry you are having an issue with AutoCAD Electrical crashing when you try to save a file. Were you able to resolve this issue?
Thank you for posting the CER #, it looks like you might not have all the updates installed and this could be causing the crash. For AutoCAD-based vertical products there will be 2 updates to install, one for the vertical installation (in this case Electrical), and one for core AutoCAD. Updates are available for Microsoft Windows-based AutoCAD and AutoCAD-based vertical products through your Autodesk Account under the Management tab, in Product Updates.
Please post an update letting the community know if you have resolved this issue.
All the best,
If a post was helpful, Likes are always welcome.
Please select the Accept as Solution button on the post(s) that answered your question or solved the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider
Liking the post.
