From the link below, you only can edit catalog database table for Microsoft® Access.
Anybody know how to edit catalog database table for Microsoft® SQL™ Server??
To Work With Catalog Database Tables
Solved by rhesusminus. Go to Solution.
I am having the same problem.
I have an SQL Server with admin / owner rights however from within Autocad Electrical I am sometimes unable to amend the data.
I can't understand why the link provided indicates that it can be done and yet we are being advised to use MSSMS.
AutoDesk Electrical Knowledge Center
To Quote
'You can add or edit catalog database tables for both the supported databases: Microsoft® Access and Microsoft® SQL™ Server'
I have attempted to either Delete or Amend a Motor Starter (MS) record. After pressing the Green Tick, the record either re-appears or the amendment reverts back.
I have tried the same with a Push Button (PB) and my edits are in-fact saved. So something is inconsistent
Help would be appreciated as this is very disconcerting.
Mark
