AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Print vs Bach Plot
6 REPLIES 6
mfinariu
178 Views, 6 Replies
Print vs Bach Plot
When I plot the drawing with plot option the render is good, but when I use batch plot the text is almost transparent.
I tried different setups but won't work. I attached DWGs and PDFs. Please  if you have any suggestions let me know.
Thank you!
6 REPLIES 6
mfinariu
in reply to: mfinariu
Her are the PDFs.
caddude1
It looks like your text color (at least the attribute I checked) is color 255. My first thought is to set all your text to white and go from there. Many non primary colors will plot light like that. Let us know if this works....
Mark Behrens
Controls Designer/CAD Manager
42 year AutoCAD user | 15 year AutoCAD Electrical user
rhesusminus
Google is your friend:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Text-is-lighter-or...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. :winking_face:
mfinariu
in reply to: caddude1
I found the soloution it's about changingAEPDFFONTALT variable to OFF.
But I have another question for you, it's about Find and Replace and using wildcard.
I have those numbers:
IP0101_00RP1-24
IP0101_01RP1-24
IP0101_02RP1-24
and I want to change them to
24-IP0101_00RP1
24-IP0101_01RP1
24-IP0101_02RP1
It's any way to do this, because I have 100 drawings and I have to change them.
Thank you!
mfinariu
IP0101_00RP1-24
IP0101_01RP1-24
IP0101_02RP1-24
24-IP0101_00RP1
24-IP0101_01RP1
24-IP0101_02RP1
Thank you!
rhesusminus
Where are those texts? In AutoCAD Electrical Symbols?
I'd go for export/import to/from spreadsheet in this case.
Trond Hasse Lie
Ctrl Alt El
