Message 1 of 8
- Mute
- Permalink
- Report
Is it possible to "lock" the title block to prevent it from being moved? Sometimes when I'm doing window select on some objects near the TB borders, I select it also by mistake and then it gets moved with the other components.
I know I can lock the title block layer, but this also prevents the attributes from being updated during a title block update. In a project with many drawings, it's not feasible to manually unlock and relock the title layer on every drawing every time an update needs to be done.
Thanks for any suggestions.
