plot project
plot project
plot project
I just installed autocad 2020 electrical and now I can't plot project from the project manager window. Version 2019 was working fine before installing 2020. but now it won't work either. Help
rhesusminus
"It doesn't work" won't make us able to help you.
- What steps are you doing? (Screenshots are gold!)
- Any error messages when it stops?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
I have the same issue after updating to 2020.  The message in the command line says.
Last plot's settings retrieved from C:\Users\WLong\AppData\Roaming\Autodesk\AutoCAD Electrical 2020\R23.1\enu\Support\user\lastplot.tmp
_.ACE_SCRIPT C:/Users/WLong/AppData/Roaming/Autodesk/AutoCAD Electrical 2020/R23.1/enu/Support/user/_WDPLOT.SCR
I tried deleting the lastplot.tmp file, and that didn't help.  I checked all of my settings against a co-worker's (which is working) and they are all identical.
I found the answer in this thread.
AutoCAD Electrical 2019 and 2020 issue with project drawings processing
I didn't change my windows settings though, I changed the path for WD_USER in the wd.env file located in C:\Users\UserName\Documents\Acade 2020\AeData as shown below.
* User temp file folder, CANNOT shared with other users
WD_USER, C:\Users\UserName\Documents\Acade 2020\AeData             NEW
* WD_USER,%DS_DIR%/user/,AutoCAD Electrical user temp file fold      OLD
