When you assign subassembly parts via the Multiple Catalog option the data is pushed into the symbol block as extended entity data (xdata). This is because there are only attributes inside of the schematic block to carry the assignments for the main part’s manufacturer, MFG the main part’s catalog number, CAT. Since subassembly parts are optional, rather than add 198 more attributes to the blocks to carry the allowed number of up to 99 subassembly parts, the software resorts to the xdata method. When you insert the panel footprints from the schematic list this xdata is transferred to the footprint. This is the recommended workflow, and it is the workflow I have used, and taught, ever since the intelligent panel layout functionality was introduced in the late 1990s. It has worked flawlessly for me and the thousands of control panels I have operaring in various facilities around the world.
If you wish, you can add attributes to your footprints named MFG01, CATO1, MFG02, CAT02, etc., and pre-load them with your required subassembly parts. Note that the xdata that gets pushed in is Electrical’s way of adding data when the block has no attributes to hold the data. But you can add the MFG01, CAT01 attributes to either schematic symbol blocks or panel layout footprint blocks in order to prevent Electrical from resorting to the xdata method. You can add up to 99 additional attribute pairs to a block, up to MFG99 and CAT99. If you add these attributes to your footprints with preloaded values you can ignore adding the subassembly parts into the schematic symbols via Multiple Catalog. Just assign the master part number to the schematic symbol and map it via the Footprint Database Editor to the footprint that contains the preloaded MFG01, CAT01, etc. attributes. When you insert the footprint via the schematic list, or insert it manually, the subassembly parts are loaded into the project scratch database and will appear in the panel BOM. Note that the link to the schematic symbol block is accomplished by the fact that both the footprint and the schematic symbol blocks share the same Installation, Location, and Tag assignment.
i wrote about this method on the Tips/Tricks page of my web site.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
