Drawing1 is created using the QNEW command by ACAD at startup
To set the template dwg for QNEW, press and hold the right mouse button while over a blank section of the dwg.
In the pop up menu that will appear after a few seconds, select Options from down the bottom of the menu.
Go to the Files tab and look for the Template Settings, when you find it, expand the entry.
Expand the 'Dwg Template File Location' and 'Default Template File for QNEW' entries.
Check the values there and make sure that they are pointing to the correct location and file.
If they are NOT correct, select the wrong entry and use the browse button the top right to navigate to the correct location or file.
However, if they are correct, then you need to check the actual template file being used and fix the problem there.
Click OK to save the changes to the settings and exit.
To fix the faulty template file, open the template file and change the settings to what they should be.
once that is done, do a SAVE AS and make sure to have the file type set to template (*.DWT) and overwrite the faulty template file.
When you have done all that, type QNEW at the command line to test the template settings in action.
Changing the Template File used gives you the option to create and use a template file to suit your company with all the settings (including the Electrical settings and layers) set to your company standards and have it be the default template used when starting ACADE.
Regards Brad
Brad Coleman, Electrical Draftsman
