Names of terminal connection points
galashkina
Advisor Advisor
Message 1 of 10
galashkina
My electromechanical superproject consists of two terminals and one wire.
Unfortunately, the terminals have internal and external connection points.
If I wire the internal and external connection points in Inventor:
And I will do the same in AutoCAD Electrical, then terminal connection errors appear.
How do I correctly assign the names of the internal (I) and external (E) connection points so that the terminals are connected without errors in the electromechanical project?
What attributes of the terminal symbol are used for this?
Replies (9)
Message 2 of 10
brad9m
It sounds like you need to set up internal jumpers.
Ribbon: Schematic Tab -> Edit Components -> Edit Jumper (aejumper)
Message 3 of 10
galashkina
No, the jumper didn't help.
Message 4 of 10
galashkina
Another super project, which consists of a button (S1), a terminal (XT:3), a lamp (H1) and two wires (3,4).
The problem is the same: I can't create an electromechanical project without errors.
In AutoCAD Electrical, the two terminal contacts have the same number (3:I).
In Inventor, I cannot assign the same (3:I) number to different terminal pins.
Can I solve this problem somehow?
Message 5 of 10
chenj
Hi,maybe you can try this:
Message 6 of 10
galashkina
Thank you for support.
I've marked the internal and external connections.
It didn't help.
Message 7 of 10
galashkina
Jens Pedersen's presentation contains the following slide:
Message 8 of 10
galashkina
And more:
It's unclear what I should do?
Message 9 of 10
galashkina
Message 10 of 10
zavier_mattson
@galashkina Did you ever figure this out? I am just now diving into electromechanical link and encountering the same hardcoded Internal and External pin assignment error. I think it has something to do with the assignment of PinL and PinR in the "Electrical Properties" of the component in Inventor:
Even though we manually name the pins "1" and "2", the electro mechanical link reports them as "I" and "E" based on the PinL and PinR assignment.
When I was testing this, the pin is always reported as "I" in ACADE
