Multi-Level Terminals - Same Terminal Number for Top/Bottom Levels
Kenny_Eichler
Observer Observer
Kenny_Eichler
Observer
Observer
Hi All,
If this has already been answered, feel free to just give me a link.  I couldn't find anything with a solution.
I'm trying to have 1 multi-level terminal block have the same terminal numbers for the top and bottom.  Being able to renumber this way would be greatly beneficial as we only label the terminal block, not each level.
See attached image, this is the desired outcome of a renumbering of terminal blocks, not top and bottom renumbering differently.
Thanks all!
james.mcmillanNYR6A
I think you can see that your desired approach is not an option. There is nothing that stops you updating each terminal to your desired approach, but you will never be able to use the renumbering facility. I think I would advise using one of the provided options.
