Moving Multiple components
stevenhcox001
stevenhcox001
Hi all,
Another newbie question.  I see on my tutorials and videos to not use non Electrical tools while drawing schematics.  So, if I want to "move" all but the first the ladder rungs down to make room for another in that location, how do I do that?
I could use the Move command just like I always have but is that the correct way to make sure that every thing gets updated correctly during update/retag?
Thanks, Steven
testsubject
Steve,
You would use "Move Circuit" and select all the rungs you want to move down.
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
OP21
You can use Move Circuit... From the Schematic Panel -> Edit Components ->
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
stevenhcox001
@OP21 @testsubject ,
That's what I was looking for!!  It updated after the move then I used stretch wire to extend the wires to the circuit that moved.
Thanks!
Steven
