Most SHX Fonts suddenly not displayed correctly
gszakacs
gszakacs
I recently had a crash and since then most fonts in my drawings (all drawings, not just those involved in the crash) are not rendered correctly.  This makes it very hard to read anything without zooming way in.  When zoomed out to see most of a drawing page I either see solid blocks or very hard to read text.  The fonts seem to be drawn as strokes rather than as screen fonts.  I don't see any problems with fonts in published drawings (PDF).  Looking into suggestions in the knowledgebase I see similar things but nothing that seems to describe this exactly.  I have used the STYLE command and found that most of the fonts I use do not show up in the preview pane.  Only a few SHX fonts like romand.shx show in the preview pane along with all of the Trutype fonts.  All of the fonts I use exist in the AutoCAD fonts directory.
Ragged-looking text:
 Non-working font romans.shx
 working font romand.shx
ramesh.kambang
Check the font mapping in the OPTIONS (type command OPTIONS), it should be pointing to acad.fmp as shown below. If it is pointing to acade.fmp, click browse and select acad.fmp.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
gszakacs
Thank you, Ramesh.  That did the trick.
