Hello everyone. I am trying to import layer settings to all of the drawings in my project. I was able to import the layers to each drawing (I was hoping to do it once project wide, not 28 times) but when I open up the layer properties the layers are there but the color, line type, and description are not coming in with the import. Does anyone know how to bring every column of data with the import. The columns come in but the data for each column does not come in correctly if at all.
Tom
Solved by rhesusminus. Go to Solution.
Thank you Jim. I'll check out that information. Thank you for your response.
Jim,
I tried the line "trick" and had no luck. The same thing happens. I lose the color, line type, and description. I should have done it in the beginning when I was creating the template but thought I could just apply the layers project wide at the end. Never did I imagine something that should be so simple to do be such an inconvenience.
Tom
This script wil create/update the WIRES_OTHER layer:
-LAYER MAKE WIRES_OTHER ON WIRES_OTHER THAW WIRES_OTHER UNLOCK WIRES_OTHER COLOR 253 WIRES_OTHER LTYPE HIDDEN2 WIRES_OTHER LWEIGHT 0.25 WIRES_OTHER TRANSPARENCY 0 WIRES_OTHER PLOT PLOT WIRES_OTHER DESCRIPTION Wires Installed By Other, No Wire Numbering WIRES_OTHER
Copy/paste it all into a file with a SCR-extension (please note the TWO blank lines at the end!!), and you can run this project wide.
HOWEVER!!!
This won't work for layers used for wires, because AcadE keeps some extra data on those layers, that isn't available through the user interface.
For import of wire layers, use this function:
Thank you Trond. I will try this out and will let you know how it works out. Thanks again!
Maybe .las file can help:
Vladimir
