Latest Updates | New Knowledge Network Solutions | AutoCAD Electrical
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD Electrical?
 Subscribe to receive updates for new AutoCAD Electrical Knowledge Network articles.
For additional updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
December 2017
Electrical - how to install addition Symbol libraries
November 2017
Add columns for the schematic components
AutoCAD Electrical : How to draw multiple cables from same port
AutoCAD Electrical : How to remove columns in Catalog browser
AutoCAD Electrical Terminal Pin Number is greyed out.
Cable Fan In / Out reports wrong from / to list
Drawing list report shows attributes out of order in AutoCAD Electrical
Missing text in dialogue boxes
Mouse button customization options are missing in AutoCAD Electrical
Raster Design Tools tab not loading in AutoCAD Electrical
October 2017
Multiple Catalog find option does not use wild cards.
Project Utilities Change Attribute size for source/destination description not working
Publish to PDF, first sheet good, subsequent sheets very small.
Rename SQL Catalogue database columns.
Selector switch with positions does not populate child with switch positions
AutoCAD Electrical 2018 installer doesn’t have the Create Deployment option
September 2017
Electrical Audit is slow when working with large projects.
AutoCAD Electrical 2017 installation error
AutoCAD Electrical: component catalog IDs do not update
Can the language conversion database be merged in AutoCAD Electrical?
How to modify P_TAG1 attribute size
Update 2018.1 available for AutoCAD Electrical
August 2017
Create a custom report field for all projects.
“A license error has occurred. Error code is: -73.125.0” when launching AutoCAD Eletrical 2018
AutoCAD Electrical : Unable to find Default Footprint for connectors
Error 25001 - Unzip error: Failed to open the ZIP file
July 2017
Unable to use source arrow command in AutoCAD Electrical
modify the inserted PLC model
How to delete existed wire annotation
Custom Terminals for Parametric PLC Build
2018: Resolving installation issues with a clean install of AutoCAD Civil 3D
Add terminal description in the Terminal Strip
June 2017
Unhandled exception error when editing child symbols in AutoCAD Electrical
Assigning data from multiple catalog records to appear as block attributes on symbols in AutoCAD Ele...
Symbol Builder Attribute Editor icons missing.
Unable to launch ACADE 2017 from its shortcut
May 2017
Which Autodesk product provides tools for labeling wires and designing IDF closets?
AutoCAD Electrical catalog database appears to not have anything in it
BOM description is missing when Catalogue number has space at the end.
Error: “misplaced dot on input” when wire tagging in AutoCAD Electrical
April 2017
AutoCAD Electrical’s Project Manager list cannot be saved
Panel schematic list does not show terminals from the schematic drawings
The Library Path menu shows ‘None’ in the Attribute Template section of AutoCAD Electrical’s Symbol ...
Toggle buttons in Details/Preview panel of the Project Manager are unavailable
March 2017
Unable to add manufacturer content to AutoCAD Electrical
Plot to Project doesn’t adhere to the previous plot setting
Cross Refenerce Moves when copy and pasted onto a new drawing
Updating bill of materials across several sheets in AutoCAD Electrical
How to add special character to a tag name in AutoCAD Electrical
February 2017
AutoCAD Electrical Catalog check does not show Description fields for component
EXPORTED_MOBILE_DATA folder created by AutoCAD Electrical
Uninstalling AutoCAD Electrical 2016 deletes network shared catalog databases
Wire number attribute lost when moving or copying schematic terminal symbol
January 2017
AutoCAD Electrical 2013 Language Packs
AutoCAD Electrical does not update project .wdp file after network outage in a Multi-User environmen...
AutoCAD Electrical: Symbol Not In Library Path
How to set new temperature for correction factor in wire size electrical settings
Insert PLC Parametric - items are missing
Matt DiMichele
