I select a component in the Icon Menu by the name of the block.
If the name of the block plcioi23.dwg (small letters), then the component is inserted without errors.
If the name of the PLCIOI23copy.dwg (large letters), then the error message is displayed:
Only small letters can be in the name of the block plcio ... .dwg?
I'm not able to replicate this with CASE, but there's something suspicious here.
I have LISP debug on.
If the sixth character is an I or an O, something goes wrong.
If I use a Q, this is returned on the command line:
OUT:wd_wdmenu_1 sym=PLCIOQ23 IN:wd_sym_do_menu_select sym to look for=PLCIOQ23
If it's an O, this is returned:
OUT:wd_wdmenu_1 sym=PLCIOO23 IN:wd_sym_do_menu_select sym to look for=PLCIOO23V
So, it's searching for the symbol PLCIOO23V for some reason.
Seems to me like a bug. A temporary workaround would be to put a dash as the sixth character, PLCIO-I23.dwg.
Are you able to replicate this probvlem @PatMurnen_Adsk ?
I was not able to reproduce any issue with case. And at first I couldn't reproduce the issue with the 6th character as an I or O. I was using the NFPA sample project to try this on and all worked as I expected. But, then I activated the IEC60617DEMO project and it failed as described by Trond. It seems to have something to do with the default ladder orientation in the Drawing Properties. If it is Vertical (default for NFPA) all works fine, if it is horizontal (default for IEC60617DEMO) then it adds the V on to try for a vertical orientation of the symbol.
I will log this. I think Trond's suggestion regarding the symbol's name is the best workaround.
Pat
The PLCIO portion of the blockname directs ACE to load the Edit PLC dialog instead of the regular Edit Component dialog. The letters PLCIO are sacred. After you insert a parametrically-built PLC module, which is made up of individual blocks that the software compiles into one block after the insertion is complete, the software will name this newly compiled block something that begins with PLCIO_. The characters after the underscore will vary because the software assigns those on the fly, just to make the compiled block unique. So a parametrically-inserted PLC symbol might have a block name of PLCIO_1E7F. Knowing this, I have always named my custom PLC modules with a filename that begins with the PLCIO_ prefix. So I have modules named PLCIO_1794IR8.dwg, PLCIO_1794IB16.dwg, etc.
