Item Numbering Standards
I have always manually set my item numbers in my schematics, I do it starting from sheet 1, which becomes item 1 and then go on from there. I have learned over time to leave some blank spaces, ie if I stop at item number 11 on sheet 1, I will start using item number 20 on sheet 2 so if anything ever gets added on sheet 1 I have space to give it an item number that makes sense with the originals.
I see that if I use the ACADE feature of automatically resequencing the items numbers it does it in alphabetical order by manufacturer, is that the 'standard' throughout all of the industries that use ACADE?
How is the situation handled that could inevitably arise when you have to insert another component within the schematic and all of the components in the schematic have items numbers assigned to them? Example, you add a component to manufacturer A that’s in the drawing set already and their previous components item numbers where 1-8, then manufacturer B components item numbers went from 9-15. The new item you added belongs to manufacturer A, so it should then become say item 9, but that’s already taken by manufacturer B. What happens then?
