Inserting the ohm symbol in the rating1 field of a symbol
snorcisa7FS8E
snorcisa7FS8E
Hello, I know I've done this way back but I forget how now. How do I insert the ohm symbol on a symbol in the RATING1 field?
alds02
Typing alt-234 works for me.
If for some reason that's not working for you, make a MTEXT box and you'll see a dropdown menu in the ribbon from which you can select ohm. Then you could copy and paste it into the rating field.
snorcisa7FS8E
Hi, for some reason that's not working for me. I get a zero instead. I did the copy and paste as you suggested, that worked.  Thank you.
