Insert WBlocked Circuit from the Tool Palette
I would like to be able to use the aewbcircuit command on a tool palette. In the Customize Commands, I have been able to get
^C^C_aewbcircuit "J:/Le/ AcadE LIBRARY/Schematic/IO CARDS and DEVICES/CIRC AB 1756-IB16" nil 1 1
to work, however, all this does, is issue the Insert Blocked Circuit command, and opens up the Browse window. I do not know how to add to the command to see the path and filename. All I would like to do is insert the blocked circuit, but I do not like to Browse so much.
I know that this forum is brilliant, because I have benefited from you all greatly.
Please let me know if someone can point me in the right direction.
Thank you,
Gail L
rhesusminus
Hi!
Seems like you're mixing up AutoCAD command and lisp a little bit.
Try:
^C^C(c:wd_ins_circ2 "J:/Le/ AcadE LIBRARY/Schematic/IO CARDS and DEVICES/CIRC AB 1756-IB16" nil 1 1)
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
rhesusminus
Take a look at the API help for the different options you have for this command:
Trond Hasse Lie
Ctrl Alt El
You were right.
I was mixing up my commands.
It works like a charm now!
I looked thru the API Help, but to be honest, I am just a hacker. I have not learned how to lisp programs.
I need to look at some online classes to help me in this area.
Thank you again for helping us be more efficient.
Blessings to you!
Gratefully,
Gail L
