AutoCAD Electrical Forum
Insert my logo cin Autocad Electrical
5 REPLIES 5
kramiaWH35Q
252 Views, 5 Replies
Hi1
I'm working on a template in AutoCAD Electrical "ACAD_ELECTRICAL_IEC" and would like to insert my logo company in the template. My logo company is in JPG and PNG.
Tags (1)
5 REPLIES 5
lee_kirkup
in reply to: kramiaWH35Q
Open the logo with MS Paint.  Select all and copy to clipboard.
Now switch to the template in AutoCAD and paste with Ctrl+V.
Resize and move as required.
rhesusminus
Inserting the logo as an Ole object (image) as described above MIGHT lead to problems. AutoCAD on Mac won't be able to display it. You really should consider vectorizing your logo into AutoCAD entities instead.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Hi @rhesusminus
What is the best way / tool to convert images into AutoCAD entities in your experience?
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
LinkedIn
www.blackcontrols.com
Please mark as "Accept Solution" if this resolved your issue. It might help someone else with the same question. Likes are welcome!
lee_kirkup
Adobe Illustrator has a trace function and can then save as a DWG.
But note that not all company logos will convert as expected when you start out with a jpeg.
We have had no issues with the OLE method for client logos.  Literally no one used AutoCAD for MAC so that's a non issue.
rhesusminus
And then we have issues with OLE objects becoming black squares in PDF's and so on every now and then. And we are seeing more and more of Web based viewers, that do not support OLE objects.
Insert an image of the logo, and just trace it with lines/polylines/circles and finally hatches.
Trond Hasse Lie
Ctrl Alt El
