INSERT COMMAND
INSERT COMMAND
dstille
INSERT COMMAND
dstille
I have created several blocks and saved them in the Jic125 folder of autocad.  I saved them there because that is where my insert command browse button points to.  I want to change the folder that is being pointed to when I click Browse in the Inseret dialog box.  Can this be done?
rhesusminus
Are you talking about the AutoCAD standard INSERT dialog, or the Icon Menu that AutoCAD Electrical has?
If it's the icon menu, you can change it in the wd.env file:
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
dstille
The standard insert.
rhesusminus
That path is saved within the registry, at this location:
Trond Hasse Lie
Ctrl Alt El
