Our company is shifting towards using circuits more and more so I just started adding them to our "standard circuits" library. I am having an error when I insert this one circuit from the menu and error is "Block _dum1 references itself". The strange part is that when I insert a different circuit...that one inserts properly (except for the wire number placement-more on that later). After I insert the second circuit I am able to back to the first circuit and then it inserts properly. I attached pictures of the error message, menu text file, and environment file. The second part to this is that when the circuit does insert I have extra wire numbers that are placed below my border block. Any ideas on what to look for? This forum limits me to only 3 attachments but I can upload more if necessary. Thanks in advance for any help!!
-Jon
