I am having issues with the position of wire numbers in various drawings.
This is just one example.
As you can see these blocks are named the same but are displaying differently.
One is rotated but even if you use the rotate command then all it does is it rotates around the red grip which still does not correct how they should be displayed.
The project wire numbering is set to below wire so I would have expected this to display more like the top number rather than the bottom which is more if inline.
If I open WD_WNV.dwg it looks like the how the bottom number is displayed.
How can I correct this? I want these to display like the top number. Not sure how you can have two blocks named the same and displaying differently in the same drawing....
