Inconsistent Cross Reference Format
Hi Guys,
My all-the-way intention is to have graphical format for cross reference in my drawing. However, it turns out to be inconsistent cross reference format even I did choose graphical format. Please see my pic. I have attached set-up page also, and I found that there is no example review there. Is it because I have to point to correct file path at somewhere else in order to get graphical format?
Hope someone could shed some light for me as I have tried thousands times but it doesn't work.
ramesh.kambang
Have you checked this (preview) in one of the demo projects? If doesn't show in the preview, try resetting the acade to default settings. Make sure you keep a copy of the your current setting in case you want to revert acade settings to your current settings.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
You will need to set-up in the PROJECT PROPERTIES (right click on project, select PROEPRTIES, click on CROSS-REFERENCE tab and set your desired format.
You will then need to apply this to the drawings in your project (select the drawings using shift and left mouse button, right click and select APPLY PROJECT DEFAULTS)
Rebuild the project (AEREBUILDDB)
Update the cross references (AEPROJUPDATE)
Hope this helps
