IEC Symbols update/add
How can I add/update the IEC-60617 symbols of AutoCad Electrical? I cannot add one by one. There are many symbols.
JeffatPrimex
Assuming you have them installed just change the projects properties to point to them. Quick check would be to look in the public users documents autocad version libs folder.
https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201...
Best regards,
Jeff
You are right, but if I need to add more symbols due to there are many missing symbols starting from Tr., Gen., ....etc. , but you know it so complicated in dealing with symbols in AutoCad electrical, because we have to identify each one through their catalogs otherwise will be unrecognized.
