I’m not a fan of the circuit builder. I teach it in my advanced class for those who insist upon using it. I show it in demos when requested, because it looks impressive. However, I find the more efficient way to use the software is by creating saved circuits with every symbol and wire predefined and saved in the circuit, including part number assignments. I can insert this circuit, increase the wire size assignment and change part numbers, and save as another circuit, for higher amperage, and so forth and so on. The only thing different between this method and the circuit builder is that I choose the wire size myself, using an ampacity chart. For a control panel, or wire in conduit, I choose from the column labeled as “bundled and confined.”
Proceed with caution if you use symbols from the IEEE library. They were not all made correctly; in fact most weren’t. I tried to get Autodesk to remove that library, but they did not. It has caused confusion.
Even if the IEEE library symbols had been made correctly, IEEE symbols and tags are intended for circuit board schematics, not industrial control system schematics. I think it was a mistake to include any IEEE library, since AutoCAD Electrical is not used for circuit board design.
The tag letters for a diode in the IEEE are CR. But CR is a control relay in a control schematic based upon the NFPA standard. The tag letters for a pilot light in IEEE are DS. In NFPA, those letters are LT. A DS could be confused as being a Disconnect Switch.
Furthermore, the JIC library is old and outdated. I suggest that you use the NFPA library for the North American market.
If a symbol in the IEEE library happens to have the look you need, copy it to the library folder you are using for your project and edit the TAG1 attribute as needed, to match the standard you are designing to. If you think you will need both a vertically-wired version and a horizontally-wired version, be sure to copy both the “V” and “H” versions of the symbol blocks.
As a bonus, you could add the copied symbol to the icon menu you have assigned to your project, using the Icon Menu Wizard.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
