I'm trying to create a script to tidy up drawings
Mike_Steel
Mike_Steel
Can someone help me with a script to set drawing/s properties to please.
I cant seem to find help with syntax and or instruction conventions.
That's not to say that I have looked in the right place 🙂
Color = bylayer
Current Layer = 0
Linetype = bylayer
Linetype scale = 1
Lineweight = bylayer
Transparency = bylayer
Thickness = 0
vladop
Тhis lisp should set defaults in all drawings of the active project:
(defun C:SetDefaults ()
  (mapcar
    '(lambda (x)
       (wd_dbx_command (setq fhdl (wd_dbx_open x "w")) "LAYER" "SET" "0" "" "")
       (wd_dbx_setvar fhdl "CECOLOR" "BYLAYER")
       (wd_dbx_setvar fhdl "CELTYPE" "BYLAYER")
       (wd_dbx_setvar fhdl "CELTSCALE" 1.0000)
       (wd_dbx_setvar fhdl "CELWEIGHT" -1)
       (wd_dbx_setvar fhdl "CETRANSPARENCY" "BYLAYER")
       (wd_dbx_setvar fhdl "THICKNESS" 0)
       (wd_dbx_close fhdl T))
    (nth 2 (c:ace_proj_data nil))))
Vladimir
Mike_Steel
thanks vladop - I'm hoping to use a script then I can use / Project / Utilities / .. to manage which Drawings I apply it to.
This is as far as I have got with it.
(command "_.COLOR"
"BYLAYER"
(command "_.LINETYPE"
"_set" "BYLAYER"
(command "_.LWEIGHT"
"BYLAYER"
(command "_.layer"
"_set" "0"
vladop
If you want to select drawings:
(mapcar
'(lambda (x)
(car (c:wd_pdwgs (nth 6 (c:wd_proj_wdp_data)) "Select files" "Default settings" nil))))
Mike_Steel
Awesome Thanks Vladimir  👍👍👍
vladop
You're Welcome
