AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
How to get dimension style to show feet and inches?
4 REPLIES 4
130 Views, 4 Replies
Greetings. I'm using AutoCAD 2024 for Windows.
My problem is
I want to create a dimension style with feet and inches, such as 4'-6". But my AutoCAD 2024 shows 4.6".
By the way, I already set up the Unit as Engineering command with Inches and Modified the Primary Unit in Engineering.
So, how can it show 4'-6" instead of 4.6" ?
Tags (1)
Labels (1)
4 REPLIES 4
rhesusminus
in reply to: 17182108059
1. This is the AutoCAD Electrical forums, not standard AutoCAD.
2. You cannot make the dimension show 6 feet when what you've drawn isn't 6 feet long. Draw something larger.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. :winking_face:
pendean
DIMLFAC variable is explained in HELP.
Try changing the dimension style unit format to Architectural
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
LinkedIn
www.blackcontrols.com
Please mark as "Accept Solution" if this resolved your issue. It might help someone else with the same question. Likes are welcome!
I thought it wasn't clear in the first answer, but if you draw a line 162.56mm long
this should dimension at 6.4"
have you tried making the line 1930.4mm long?
