Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
HOW TO CREATE CUSTOM TERMINAL BLOCK AUTOCAD 2026
Robertojoa21
Message 1 of 11
Robertojoa21
HELLO GUYS.
I would like to know how to create a custom terminal block.
I tried following the instructions on this website:  https://blog.hagerman.com/2014/02/04/multi-pole-multi-level-terminal-blocks/
but the terminal block is not showing up in the Terminal Strip Editor.
Replies (10)
Message 2 of 11
jaya_priya_ramasamy
Hi @Robertojoa21
There is one article from @arshdeepsingh404 for this topic. You can try that and see.
Solved: Editing Terminal Footprint Symbol in AutoCAD Electrical - Autodesk Community
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Message 3 of 11
arshdeepsingh404
Thanks @jaya_priya_ramasamy for sharing the article.
@Robertojoa21 The article should walk you through how to create a new terminal block from scratch. If you have any questions, please feel free to let me know.
Cheers
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM® | CMSE® | Autodesk Expert Elite
LinkedIn
Message 4 of 11
Robertojoa21
I FOLLOWED YOU INSTRUCTION BUT DOESNT WORK.
Message 5 of 11
Robertojoa21
HELLO.
I FOLLOWED YOU INSTRUCTION BUT DOESNT WORK WELL. SEE THE UPLOADED PICTURES
Message 6 of 11
arshdeepsingh404
Hello @Robertojoa21
Can you please provide more information on which part doesn't work?
Did you map the catalog to the footprint .dwg file using the footprint database editor?
Can you post a screenshot of the Footprint Lookup Table where you added the entry for KN-T12?
Arshdeep Singh
LinkedIn
Message 7 of 11
CGBenner
@Robertojoa21
Hello, do you still need help with this question?
Chris Benner
Message 8 of 11
Robertojoa21
@arshdeepsingh404
I already added on Footprint Lookup Table and create on the catalog browser.
So after save all changed i made and then go to editor terminal block, i cannot see the terminal block that I already created
Message 9 of 11
Robertojoa21
yes!
Message 10 of 11
arshdeepsingh404
Hi @Robertojoa21
Here is a full video guide on how to add a custom terminal footprint. I have also attached the footprint for KN-T12 that I used in the video.
Let me know if this works or if you have any questions.
Arshdeep Singh
LinkedIn
Message 11 of 11
arshdeepsingh404
Hi @Robertojoa21
Were you able to resolve your issue using the video tutorial?
Arshdeep Singh
LinkedIn
