How to add User1-User20 to wire label report
I am using AutoCAD Electrical 2015. When creating a wire layer, I use User1 column header to indicate the wire part number in order to create a report for the panel builders where they can find what type of wire to use. Since I migrated from Autocad 2014 to 2015, I have not been able to do this report because the User1-User20  are not in the wire label available fields to add to the report. I have been trying to find how to make them available in wire label report without success.
Could someone provide some guidance on this matter?
Thank you in advanced.
Carlos Urdaneta
yuvaraj_jaganathan
Hi Carlos Urdaneta,
With the current design, the user1 to user 20 field will not appear in Wire label report.
We have noted down your request and have forwarded to our design team to have a look at it.
As a workaround,
You can try with From/To report that gives the option to add USER1.
Note: The USER1 the enty is limits within drawing level.
regards,
Yuvaraj J
Yuvaraj Jaganathan
Senior QA Analyst
www.autodesk.com
