how edit created component of block
pcwortex
pcwortex
I created a component block, but by mistake, I assigned the terminal to a different layer. I want to change the component's layer from "wire" to "0." I tried editing the block, deleting the components,creatted new components, and saving the block, but nothing changes in the drawing. How can I change the layer of the block component? I don't want create same new block. I also made a video to show the issue.
rhesusminus
Run the swap/update block with the updated option after editing a block that's already inserted in your project.
https://help.autodesk.com/view/ACAD_E/2024/ENU/?guid=GUID-4673F13C-93D5-4C74-8F15-77AB8B4EB9EF
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
pgarciadlc
Hello.
I have also had problems modifying already created blocks, the same as you.
What I have done a while ago is:
  • Open a project from 0 without that block inserted previously, or delete and purge that block so that it does not appear as part of that sheet from which you will make the modification.
  • Open symbol builder and in the Name part from "browse.." look for your component to modify. Select and edit (OK).
  • Once edited, in the symbol builder tab click on "done", save as if it were new and click "yes" when asked if it should replace the previous one.
Kind regards,
Pablo
pcwortex
@rhesusminus If I want to change or update a block using "Swap Blocks," I need to create a new block with only the minor changes I want. Then I can replace the entire block with the new version. Am I correct understand?
pcwortex
@pgarciadlc Your version works, but this approach is more like a last resort. There should be a more logical solution, as otherwise the 'Edit Block' function doesn’t serve its purpose.
rhesusminus
Yes. That is exactly how it works, and this is just how AutoCAD works.
Trond Hasse Lie
Ctrl Alt El
pcwortex
