how create inputs and outputs in a blok
i need to add or insert inputs and outputs to blocks, I´m in the block editor but i don´t know what command to use
Icemanau
A few questions...
First of all, What version of ACADE are you using?
Which block editor are you using? ACADE has three different editors and only two are set up for doing the intelligent blocks that ACADE uses.
You have the standard ACAD block editor which does not give you a list of the appropriate attributes to add. Do NOT use this editor.
The first ACADE one is called the Black Box builder and is fairly hard to get to. It is a legacy command and has been superseded.
The second ACADE one is the latest and is designed with a set of drop down menus on the left (default location) with all the correct atributes and other parts to make the block act intelligent. It is called the Symbol Builder and this is the one you should be using.
Next, are you referring to wire connection when you say Inputs and Outputs?
If you are indeed talking about the wire connections, look at the menus that appear when you start the Symbol Builder.
There should be a list of sub menus in this order
Required
Optional
Wire Connection
Pins
Link Lines
Inserted Link Lines.
Required is a list of ALL the required attributes to allow the symbol to work with ACADE
Optional is for attributes that are not required but could be used depending on the purpose of the block
Wire Connection is how you set up the various wire connection points.
Pins just list any wire connections that have already been set up
Link Lines is how you add the connection point for the dashed link line as used in multi pole devices
Inserted Link Lines is the same as Pins but for the Link Lines.
Select the type of wire connection you require using 'Other' in the Wire Connection sub menu. Make sure to set it as your default if you always use it.
If the connection is set up correctly, all you need to do is select the direction the connection will be coming from and insert it into the block. ACADE sets everything else up in regards to the attributes names and other settings.
Regards Brad
Brad Coleman, Electrical Draftsman
thank you.
I reffer to add "pines", for example: I have a block PID and I want to apply it input and output, also when I need to use this block in a diagram y I will have to do a wire conection my block indicate its pines of inputs and outputs. Smiley Indifferent
