Hiding unwanted lines when printing
hello
been editing a drawing trying to get the hang of using autocad 2016 at college.
Could anyone tell me how I print without the scaling lines all over it?
also has anyone a recommendation for converting it to PDF?
any help much appreciated.
rhesusminus
What pritner driver are you using?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
TRLitsey
Hi there
OK, so by what you have said I am going to assume those are real lines you have drawn in to scale from one drawing to another.  That being said, type LAYER on the command line, create a new layer called something like SCALE, on the layer properties click on the little printer icon to turn it off.  Put what you want on that layer and you will see it in the drawing but it will not print on paper or if you create a PDF.  What ever is on that layer will just not transfer to any PRINT function.
Good luck
Stuff to not print ....
 Use print tool and select DWG to PDF
Please mark as a solution if this works for you, kudos are always welcome
