Having a little bit problem with creating 1794-OB32P module
bachphi
bachphi
Since Autocad does not have the module, I went into PLC editor db to create one. I copy it from 1794-IB32 and change everything  acordingly, but only the first description indicate OUT 0 correct, but the rest is still said IN 1, IN 2 ...
How do I correct this? TIA.
PatMurnen_Adsk
In the PLC Database Editor, each I\O point is defined separately. So you would need to select each point in the top part of the dialog and then edit the assigned values for that point in the grid area right below the list of terminals for the module. Repeat this for each terminal I\O point that makes up the module.
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
bachphi
Got it. Thx u!
PatMurnen_Adsk
Glad you are ok now. If my suggestion was the actual solution, go ahead and mark it that way so anyone else having the same issue will see it.
Pat Murnen
Pat Murnen
Autodesk, Inc.
