I have ACADE2014 64 bit on Win7. I have a block that shows 2 little square objects on Layer0. All objects in my block are on various other layers. I am unable to select them with any command. They are outside the actual block that I created. Note that nothing was imported.
If I erase the entire block, the ghosts seem to disappear along with the block. If I erase each piece of the block, they do not disappear despite all parts of the block being erased. With all parts of the block erased, I go to erase all and it finds nothing to erase. Yet the ghosts persist.
Next I locked all layers except layer0 and do an erase. Tells me 0 objects were erased and ghosts persist.
If I copy the block objects, the ghosts are also copied.
In the block editor, I need to be zoomed out and then they appear. Despite them being within the previous zoom range. Which means if they were not ghosts, you would be able to see them in the zoomed in screen.
When the block is inserted to the drawing, again you need to zoom out as in the block editor to see them. Also when you do a zoom all, the extents are extended to include these ghosts which lay outside the drawing border and the drawing limits. However I have to zoom out farther to see the ghosts even though they were in the zoom all screen extents.
Also I have tried selecting all the parts of the block and changed layers which also changed there color. The ghosts seem unaffected by this and turn on and off with turning layer0 on and off.
Can anyone tell me how to get rid of these ghosts? And how they get there so I can prevent it in the future?
