Announcements
General
General
Hello All,
Please, can anyone explain to me to me what are those WDs file on picture are for? and also what are they located? I can't find them anywhere even though everything works just fine. thank you.
jseefdrumr
These are command callouts for icons in the Icon Menu.
In this screenshot, you're in the Icon Menu Wizard, and you've told it that you want to insert a command. The list of WD functions are the ones that are available. For instance, the one that's already highlighted will insert a specific (rather than general) panel symbol, and won't prompt you for its rotation.
WD-2UNIT would be used to make a parametrically built 2-pole symbol, like a circuit breaker or line filter.
These commands aren't really files that you have access to without delving deep into APIs (and maybe not even then).
There's some pretty decent material on the Icon Menu and its Wizard in the Help.
Jim
Jim Seefeldt
Electrical Engineering Technician
