filenames are renamed/changed from uppercase to lower case after updating??
mlaterradeHPV27
Message 1 of 15
mlaterradeHPV27
I am having an issue that happens when I update a block that I have inserted on all of my drawings. It is an ACADE block with standard attributes. When I update the desc fields, and it runs the update to all the other instances on each drawing of the project, it changes the filename from upper case letters, to lower case letters. I am able to watch this happen in windows explorer as it goes through all of my drawings. Is there a way to fix this (or prevent this from happening)?
Replies (14)
Message 2 of 15
rhesusminus
I'm not 100% sure, but I believe this was a bug in an older version of AutoCAD Electrical. What version are you running?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 15
mlaterradeHPV27
AutoCAD Electrical 2020, and it also happens with 2019.
Message 4 of 15
rhesusminus
Just did a quick test, and I'm not able to reproduce this in 2020.
- Do you have your files on a server? If so, can you try the same with the files locally?
- Are you implementing XREF in some way with your drawings?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 15
mlaterradeHPV27
I will try locally...
Message 6 of 15
mlaterradeHPV27
I tried with a local copy of the project and the results were the same. It only happens when it runs through all of the drawings, and updates the DESC1 field of a block that is on all of the drawings.
I have attached the block that is being updated.
Mike
Message 7 of 15
rhesusminus
I'm still not ale to replicate this.
How are you using that block? Do they all have the same TAG?
I tried to call them all S1 on multiple pages, changed DESC1 on of them, and it asked to update the other drawings as well.
Filenames stays in the same case they were.
Trond Hasse Lie
Ctrl Alt El
Message 8 of 15
mlaterradeHPV27
Yes, I am using all of the standard attributes. The block has the same tag, so that every time that I change the description, it goes to every instance of the block throughout the drawing. Not sure why, but evfery time it changes my filenames to lower case.
Message 9 of 15
I thought I read somewhere about a 2019 update that is needed to fix XREF's from doing this (which is probably why Trond was asking), maybe that update touches filenames if you don't have it?  I'm not sure how, way above my head just sounds similar.
Message 10 of 15
JeffatPrimex
You're stuck with it until they fix it and it seems that there is a lot of places in their code that have this issue:
https://forums.autodesk.com/t5/autocad-electrical-forum/file-name-case-issue-is-back-2020/m-p/874998...
Time to fix this issue too.. Chop Chop.
Message 11 of 15
quentin.contreras
Autodesk Support
Autodesk Support
@mlaterradeHPV27 have you tried to switch to Flip DWG Name to Upper Case and then do the update to see if that will switch your file names back to upper case?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 12 of 15
JeffatPrimex
That's funny. Is say's we can't fix the issues right now so we'll give you the option to manually waste your time changing the case on all of the files that the program has changed on some of your files.
Programming 101
Step 1
Store current state
Step 2
Run program
Step 3
Restore state from step 1
End program
Answer to your question is I like my extensions lower case.
Best regards,
Jeff
Message 13 of 15
mlaterradeHPV27
I am not familiar with that command. Where is it located?
Message 14 of 15
drew_dewit
I am able to replicate this issue in 2019. Was there a fix or is it an open issue?
Message 15 of 15
HARISH-WAHO
AutoCAD update 2019.0.2 will be solve this issue. Download and install it.
