FileDIA keeps resetting
Snettles7
Message 1 of 18
Snettles7
everytime i close out of Autocad Electrical, my FileDia resets back to 0 even though it is preferred at 1. how can i fix this so that i dont have to keep switching it back.
Replies (17)
Message 2 of 18
testsubject
Frequently, ACE will turn FILEDIA off while it is doing something and then turn it back one when done. If it gets interrupted during this time and you get shut down, FILEDIA is left at 0.
Many of us have added this {"FILEDIA" 1} to the wd.env to force it back on. (It is located under this heading "* Project and drawing-related paths and settings")
WD_OPEN_DWG,(command "_.ZOOM" "_E" "FILEDIA" 1)
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
Message 3 of 18
Snettles7
how do you Edit WD.ENV?
Message 4 of 18
testsubject
You can edit it in Notepad. Just do it while Autocad is closed.
Bob Hanrahan
Ace User since 1998
Message 5 of 18
Snettles7
i updated the wd.env file its still not flipping the FileDIA to 1.
Message 6 of 18
rhesusminus
Did you also remove the asterisk in front of that line?
Maybe you can share a screenshot of that part of the wd.env file?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 7 of 18
Snettles7
i removed the asterisk still not working.
Message 8 of 18
rhesusminus
Only thing I can see is WD_OPEN_DWg , not WD_OPEN_DWG
Does it make any difference?
This will only apply when you open the drawing from the project manager, by double-click or right-click+open
Trond Hasse Lie
Ctrl Alt El
Message 9 of 18
Snettles7
no still not working.
Message 10 of 18
rhesusminus
What is not working?
Isn't that code executed? Isn't any drawings opened? Any error messages?
Press F2 after opening the drawing to see the command line history.
This is what mine says after opening a drawing:
Opening an AutoCAD 2018 format file.
Regenerating model.
AutoCAD menu utilities loaded.
AutoCAD Electrical menu utilities loaded.
Command:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Command:
Command:
Command: (PROGN (COMMAND "ZOOM" "E")(SETVAR "FILEDIA" 1))
ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: E
Command: 1
Command:
Trond Hasse Lie
Ctrl Alt El
Message 11 of 18
Snettles7
My FileDIA keeps resetting back to 0
Message 12 of 18
johnfraser3019
I think your missing a comma after your closing bracket:
John
Message 13 of 18
Snettles7
made this update. still not working, i even tried restarting my computer. still once i open autocad FileDIA resets back to 0.
Message 14 of 18
rhesusminus
Are you able to OPEN any drawings?
We're really trying to help you here, with a minimal amount of information.
If your car won't start, repeating "my car won't start" isn't really helpful to the ones trying to help you 🙂
Trond Hasse Lie
Ctrl Alt El
Message 15 of 18
testsubject
It looks like you are also missing the space between [command] and ["_.ZOOM" "_E"]
The command line will not start without this space.
This is what the whole line should look like.
WD_OPEN_DWG,(command "_.ZOOM" "_E" "FILEDIA" 1), AutoLISP prog or expression to autoexecute when dwg opened from PROJ dlg
Also, to be clear, this only works if opening drawings with AutoCAD Electrical Project Manager. If you try to open a dwg from Autocad's "Open" command it will not work.
Bob Hanrahan
Ace User since 1998
Message 16 of 18
Snettles7
Thank you.
Message 17 of 18
hwhite
You may want to look at this article as well, it is an alternative option that will work whether you use the Project Manager or not, and also works in other flavors of ACAD.
https://resources.imaginit.com/support-blog/autocad-electrical-filedia-resets-to-0
Message 18 of 18
johnfraser3019
I've used both methods.  I prefer the acad.lsp approach from the article you linked, it's just seems to be a little more seamless to me.
